Help with 4870x2 Please
26 Dec 2009
North
Hi, Ive removed my watercooled 4870x2 from my pc. Trying to put it back together with some problems. If anybody could point me in the right direction would be appreciated.
A) Ive lost the screws!!
8 x spring type ones for the heatsinks
and i think 9 others for the casing ( i think these are 8mm M2 Countersunk screws)
B) lost some of the thermal pads for the chips
Anyone know what are the screw types required along with where i can buy them from. Plus where can i get the thermal pads from?
Many thanks
Near me is a shop called Nuts and Bolts, its got every type of screw, nut, bolt, washer you could ever want. Do you have something similar near you?
Akasa do thermal pads, browse the internet.
Just checked ocuk, they got akasa and coollaboratory thermal pads.
I don't know what type you need, I presume you lost the originals when you fitted the waterblock, next time you will remember to put them somewhere save, surprised you never put them with the heatsink and case, have another look around.
