Help with 6600/680i overclock
Permabanned
18 Oct 2002
I've just upgraded from my old P4 to a Core2 6600, Crucial 2GB Tenth Anniversary Kit, Evga 680i 8800 GTX. I've got it all togther and i'm trying to get my head around all this new tech :) I've got this so far
But i've been looking around the fourms most people seem to be running at 1:1 divider kinda like this
I just carnt seem to work out how to do this in my bios and get it to boot :P
Could someone point me in the wright direction please
Thanks for anyhelp :)
Nice one m8, should use the unlinked memory though on the board to boost that :)
I have mine unlinked 9x 1600, memory at rated 900mhz, 1.337vcore
After running at 1.475vcore for a week ive found that i can use a lot less volts, before orthos wouldnt look at this sort of volts, all seems good now.
Might be a mix of burn in and p23 bios making it a lot more stable with less volts.
One thing thats bugging me is my HD are showing as removeble, so i have that little icon in my tast bar. Seems strange as there not removeble any idea how i can get rid of it ?
If your sata drives are showing up in Safely Remove Hardware, this registry hack will allow you to fix it.
1. Click Start -> Run
2. Execute regedit
3. Navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\nvata <-( can have 32 or 64 on the end depending on which version of xp your useing )
4. Click Edit
5. Select New > DWORD value
6. Name this DWORD: DisableRemovable
7. Double click this new DWORD and set its value to one (1).
8. Close Regedit and reboot
:D
yea i thought it was weird having my drives as removable, thought something was wrong :)
It s perfectly normal, its the way its ment to be for this motherboard :)
Cheers for the crack though, ill keep a note of it :)
Looks good m8 :)
and the cpu test low to no fps is normal ;)
Might want to check it with Orthos for around 9 hours to be sure its stable, not sure the board likes 1T command rate, not tried it for long though.
