Help with a £700~ Spec
1 May 2010
I am looking for a spec around 700 squid. I Dont need an OS or keyboard + mouse or screen
The main use is to play WoW however i want an apt pc to allow me to play other games....Although i was an nvida fan boy (:D) i quite like the look of the new 6870s
However im undecided if i should go more for a hex core...or just go quad and spend more on the graphics card
ideallly i would like to fit a 6870 + i5/955 in budget with a good mobo but i always seem to add more then required
Upgrading from a 2.2ghz dual core 1gb ram vista pc im sure i will see an improvement:cool:
HIS ATI Radeon HD 6870 1024MB - £199.99
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - £144.98
MSI P55-GD65 Intel P55 (Socket 1156) DDR3 Motherboard - £99.99
XFX 650W XXX Edition Modular Power Supply - £69.99
Corsair XMS3 4GB (2x2GB) DDR3 - £61.09
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - £44.99
Coolermaster Elite 430 Case - £41.99
Titan Fenrir Evo CPU Cooler - £32.89
LG GH22LS50 22x DVD±RW SATA ReWriter Lightscribe Drive - £14.99
Sub Total : £605.03
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.50
VAT is being charged at 17.50%
VAT : £107.72
Total : £723.25
Can't really beat an i5 for gaming. A hex core is overkill.
That spec above is pretty sound. I went from a 1.7 ghz laptop to my current spec ( even at stock) and I won't even touch my working laptop anymore it annoys me with its load times.
You could downgrade the case to save some bucks if needed
Do what I do- install Ubuntu on your laptop so it works as a portable internet browser / office machine. You won't play games on it anyway, and load times are a hundred times faster in Ubuntu than in Windows.
Alright thanks guys i will mull over it for abit before i buy!
Honestly, Jony's reply was the perfect build :). Switch to a 460 1GB if you still fancy nVidia, and you can downgrade the PSU and get rid of the cooler if you want to save money and you're not overclocking, but really I'd just order what he listed there.
Still though, always good to think about what you're buying.
Cheers never really considered it. (Sorry for hijack)
