Help with a BlueScreen
9 Oct 2008
Somerset, UK
Hi, I'm looking for some help identifying why I am getting BSOD.
So I've had this computer system running for around one year now, and never had any major issues. Managed to overclock my 1055t to 3.6 GHz easily and unlock my 6950 to a 6970 with no problems.
About a month ago I was playing StarCraft 2 and I got a BlueScreen, the PC restarted itself and all was okay. I didn’t really think anything of it since it was the first time it had ever happened. In the past two weeks in happened one more time, so i decided to run memtest86 on my rig, Left it going for around 3 hours as it was testing 12GB of RAM ( It finished 2 passes with 0 errors ). Now that I've purchased Battlefield 3 I get a BlueScreen almost every time I play for any amount of time. It can happen within 10mins or 3 hours of playing. I've kept an eye on my temperatures CPU staying below 50C and GPU staying below 80C.
Last night I ran prime95 blend test overnight and the system stayed stable.
Any help in finding the cause of this would be great :)
My Rig >
AMD 1055t @3.6Ghz 1.368Volts
Biostar TA890FXE Bus speed 257Mhz, HT link 2056Mhz, NB Freq 2056Mhz
4GB GSkill RAM and 8GB Crucial RAM all running at 685Mhz 9-9-9-25-40-2T @1.5V
HIS 6950 flashed with 6970 BIOS
XFX 650W PSU
OCZ 60GB Vertex 2
Samsung 1TB F3
Asus Xonar D2
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2011-11-01T19:05:30.064414900Z
EventRecordID 652519
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer JamieWood-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
Might be worth restoring the CPU back to stock settings to see if the problem remains. Ideally need to run memtest86 longer than you have, preferably leave it on overnight. Also noticed you have different RAM, make sure it's all running at rated speed and timings that both sets will cope with.
