Hi Doomedspeed, had a chat with my son and he say's the rendering does no take that long as its only Jewellery often quite small.
But he says the PC that they are using falls over now and a gain when rendering, etc.
LoL, l won't tell you what they have been using, l built it nearly 4 years ago for gaming and general use say no more.
So your 1st Spec might be the thing, would it be worth waiting for the Haswell 4790k?
Again thanks,
Oldphart.
Well that's fine then, even a 4670k (or newer equivalent) would deal with that fine.
The 4770k has its advantages though and as its still in budget, why not.
I think you can drop the GPU down aswell, may be the 750 or 750ti.
You're looking for something very similar to the spec I did for benji.
My 2p ....
YOUR BASKET
1 x Intel Xeon E5-2620v2 2.10GHz 6-Core with Hyperthreading & Turbo (Socket 2011) - Retail £319.99
1 x Kingston HyperX Beast 32GB (4x8GB) PC3-14900C10 1866MHz Dual Channel Kit (KHX18C10AT3K4/32X) £249.95
1 x Asus P9X79 Intel X79 (Socket 2011) DDR3 Motherboard £184.99
1 x MSI GeForce GTX 750Ti OC 2048MB GDDR5 PCI-Express Graphics Card (N750Ti-2GD5/OC) £101.99
1 x Antec P280 Super Midi Tower Case - Gun Metal Black £99.95
1 x Intel 320 Series 120GB Internal SSD SATA 3GB/s 2.5" 7mm (SSDSA2BW120G3) £59.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £59.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £55.99
1 x Raijintek Themis Direct Contact CPU Cooler £19.99
Total : £1,167.83 (includes shipping : £12.50).
Awesome but wildly Over the top I think.
