Help with a build please
28 Nov 2024
London
Hi All,
Wonder if you can give me some advise please.
I currently have a gaming system with i7 9700 and DDR3 ram. I upgraded the the GPU to 3090ti 18months ago.
So today I want to upgrade the rest of the PC - Motherboard, CPU, Ram to maximise the performance for the 3090ti, but also make it futureproof for a 4080/90 next year.
TIA :)
WIFI not required - 1k no PSU, Storage or case required.
The 9800x3d is currently the fastest gaming CPU but it's on pre order then there's the previous gen CPU the 7800x3d which is available but it mite be worth waiting.
X870 motherboard and 32gb of 6000mhz C30 memory is what I would get although you do have the budget to up to 6rgb of memory if you prefer and get a better motherboard.
Example.
My basket at OcUK:
Total: £797.96 (includes delivery: £7.99)​
For gaming yes the CPU is overkill but if you do productivity , rendering stuff then the extra cores will be beneficial otherwise the 7800x3d will perform virtually the same in gaming.
9800x3d will be faster.
Motherboard the newer x870 offer better value and pcie5 as standard and memory you want 6000mhz C30 which is optimal.
There's little point buying all those extra cores if you're just a gamer, get the 9800X3D.
Motherboard, what features do you need/want from a board?
Some of the major features that influence board price are:
- High speed LAN (e.g. 5Gb/10Gb)
- USB4
- Number of M.2 slots
- Number of PCI-E 5.0 M.2 slots
- PCI-E 5.0 graphics
- integrated DAC/AMP
2 M2 Slots, not sure about PCI-E stuff, I have a 3090ti so that will need to work. High speed LAN would be good and integrated AMP
Faster than 2.5 Gb? X870 Tomahawk has 5 Gb, though I don't think it has integrated AMP. Strix B650E-F and B650E-E have integrated AMP, but LAN is 2.5 Gb.
There's a spreadsheet linked to here:
If you hover over the LAN chipset it will tell you the speed.
Unless you’re routinely transferring huge files between machines or a local server then you’ll likely never max out a 2.5GBE link. Very few places offer an internet connection that matches that, never mind exceeds it. For that reason a 670 board is, IMO easily sufficient.
