Hello,
Bought some RAM from here not so long ago (http://www.overclockers.co.uk/showproduct.php?prodid=MY-177-OC&tool=3) and also a MOBO (http://www.overclockers.co.uk/showproduct.php?prodid=MB-366-AS). PC kept giving me BSOD and after a lot of troubleshooting i found out the RAM is not noted as a "capability RAM" in the MOBO although the MOBO supports DDR3 etc. I was told this is most likely the problem. I'm just triple checking with you guys that it could be and how likely it is?
Ive had a master in BSOD working on it and he checked my dump files and everything and couldn't find anything wrong. Memtest86+ is throwing up like 11,000 errors and I'm told this can be caused by the MOBO having the RAM that isn't compatible.
Can anyone help?
Thanks.
Can anyone help?
Thanks.
