Help with a friends pc
29 Feb 2012
London
Hi guys,
My friend has been having the following issues.
PC randomly freezes, mouse flickers and screen goes black – looking for troubleshooting advice
I'm looking for some advice diagnosing an intermittent problem with my PC. Sometimes, when I turn it on, the mouse cursor starts flickering or jumping all over the screen, the display intermittently flashes black, and eventually Windows freezes completely. I then have to force the PC to shut down.
PC specifications
- Case: HYTE Y70 Touch (with integrated screen and GPU riser connection)
- CPU: AMD Ryzen 7 9800X3D
- Motherboard: ASUS PRIME X870-P WIFI
- GPU: NVIDIA GeForce RTX 5080 16GB
- RAM: 32GB DDR5, running at 6000MHz
- BIOS: Updated to version 1681
- Graphics: AMD integrated Radeon graphics available through the CPU
Troubleshooting I've already tried
- Tested each RAM stick individually, using the same motherboard slot. The issue persisted with either stick.
- Swapped graphics cards to test whether the original GPU was faulty.
- Tested the PC using the CPU's integrated graphics. Windows ran smoothly, without the mouse flickering or screen going black.
- Disabled and physically removed the dedicated GPU. Again, the PC ran smoothly using integrated graphics.
- Updated the BIOS and tried changing the PCIe link speed from Auto to Gen 4, but this didn't resolve the problem.
- Tried updating the NVIDIA graphics drivers, but this didn't fix the issue. Windows has also crashed during attempts to install the drivers.
- Tested Safe Mode, where the mouse was stable and the system behaved much more normally.
- Initially reset Windows during the earlier stages of troubleshooting, but the problem persisted.
What I've done with the original place of purchase.
I've been in contact with original place of purchase, where I purchased the components. They suggested the issue could potentially be PCIe-related. I sent my original RTX 5080 back to them for testing, but they reported that they couldn't find any fault with the card.
During my own testing, I installed a replacement RTX 5080 from another PC into the problem system, and it booted and ran smoothly. This made the original GPU seem like a possible culprit, but their testing didn't identify a fault.
Original place of purchase have also suggested that the problem could be the PCIe riser cable or GPU connection in the HYTE Y70 Touch case, as the graphics card connects to the motherboard through the riser rather than directly into the PCIe slot.
What I'm trying to establish
Given that the system runs smoothly on integrated graphics, and a replacement RTX 5080 appeared to work in the same system, what would you investigate next?
Could this be a faulty or intermittent PCIe riser cable, a motherboard PCIe slot or signal issue, GPU power delivery, a driver/software problem, or something else entirely?
I'd appreciate any suggestions for further tests that could help isolate the fault before I start replacing components unnecessarily. Thanks!
I still think it's the GPU.
When you switched out the GPU for the other 5080 did you use the riser cable?
If yes then I'd say the card is the problem.
If not then try the current card without the riser.
Power supply? If your card is drawing more than the other 5080 it could be tipping the PSU over the edge.
I was going to suggest re-seating the CPU as it could the a PCIe lane connection issue, but I think testing with the other 5080 rules that out.
What happens if you put the 5080 in a different PC?
During my own testing, I installed a replacement RTX 5080 from another PC into the problem system, and it booted and ran smoothly. This made the original GPU seem like a possible culprit, but testing didn't identify a fault.
That's the most significant part to me.
Risers are always suspect, but if it worked fine with the alternative card, then it seems unlikely to be the problem.
Did the other card run with PCI-E Gen 3 or 4 instead of 5.0?
Looking at the case, I suspect it can't mount cards without the riser?
The PSU is the Corsair HXi series HX1200i 80
Yes used the riser cable when swapped GPUs.
Will try the GPU in a different machine.
He said It was on Gen 4 setting and you cant mount without the riser, hes bought a new case.
Could he not have just tried building outside of the case?
Would have saved buying a new case and he would be dismantling the PC anyway.
Has he tried different monitor cables in different ports?
Although if another 5080 works, it kind of rules this out.
Testing the suspect 5080 in another PC is good call.
Yeah im going there next monday to rebuild it for him
just one more thought...have you tried running the ram without EXPO and seeing if there are still issues?
