As said above, i think Fractal have some really nice cases. The Arc mini is a lovely case and they are releasing a new node version, that i think personally looks awesome.
Completely. The airflow is all messed up, no way to put radiators in. Can't use the bottom GFX bay if you want to use a ODD. It would have been much better if they just made the micro atx version of the prodigy just a bit bigger with the same internal design
^^^^ lian-li layout
nice mod!
you see their a51? looks sweet
i have 350d and airflow to gfx cards could be better, but thats the same with most window cases
silverstone has it right with the air coming in from the bottom
i want do a new build and i want a ft05
but i dont think they will be cheap
The air doesnt come in from the bottom of the TJ08 it comes from the front. As for the airflow to the gpu in the 350D what fans are you using at the front?
