Help with a new build, component advice required.
8 Jan 2013
Birmingham
Hi All,
I'm looking to build a new computer for a friend and without wanting to sound like a broken record... I know about hardware how it all goes together but I've not built anything new in a very long time (I'm still rocking a 2500K!!) and would like some help in choosing the components.
I've looked at both teams, red and blue and have no preference of one over the other. I quite like the idea of an Intel mid range chip but I'm pretty sure an AMD will suit his needs also. If I could get a couple of options for both that would be great.
It will be used for mainly for work purposes, large spreadsheets/Word documents and would even like to load up a couple of VM's. Not a huge gamer but would like the option to play a few at a reasonable frame rate if the opportunity arises (nothing more than 1080p). Also would like to use it to watch a few movies and browse a few photo's etc nothing else too demanding.
A couple of other requirements, it may occasionally be connected to a tv so it will need a HDMI connection. I have an OS, Monitor, KB, Mouse and case is a personal choice so that can be left out too. I understand ill have to check clearances with CPU coolers and RAM when we come to purchase. Now its a lot to ask but the budget is £500, or as far under this as possible. Its a lot to ask but I'm sure you geniuses can work your magic.
I do have a couple of quick questions. Ram speed, im guessing on a build like this 1600MHZ will suffice but whats the difference between this and say... 1866 or 2300? In a gaming rig how much of a difference does this make?
Also is it worth waiting for Intel's new chips to be released? are they going to offer a significant performance increase worth waiting for (or will the older chips drop in price enough to be able to pick up a bargain?).
As always, thanks in advance for your help!
Thanks for the help Mickyflinn, got any advice on a AMD build? I know its not quite in the same league as the Intel chip you have recommended but I've been looking at the AMD FX8320 or FX8350. Ever used one of these in a build?
