- 13 May 2007
- Bristol, UK
Hi
i am new here but thought i shoudl get some expert help before i attempt this project. I guess memory is the write section to place this under as it is a memory query.
Anyway.....
My aim in about 5 or 6 weeks time once i get paid for some summer work while i am off uni is to upgrade my pc with the following kit :
1 x Asus Striker Extreme nForce 680 (Socket 775)
1 x Intel Core 2 Quad Pro Q6600 "LGA775 Kentsfield" 2.40GHz
2 x OCZ 2GB (2 x 1GB) PC2-8500 1066MHz SLI-Ready Edition Dual Channel DDR2
[4gb total]
2 x 7950 GX2 - 1GB PCI-E Graphics Card [To use quad sli]
I will keep the currrent case and power supply and sata drives as they are more than adequate
my problem is relating to the "sli-ready memory" i know the striker extreme supports ddr2 800 but it also apparently supports "sli-ready 1200mhz" memory.
My question is therefore will the pc2-8500 sli-ready memory work?
firstly because of the type of memory it is ... i have searched the net and cannot seem to find a straight answer regarding sli-memory and secondly due to the infamous memory glithces with the 680i platform, although these ae apparently fixed by supplying the correct voltages as the striker extreme requires a good 2.1v to get going
not the 1.7v or 1.8v that is automaticaly set.
any advice is greatly helpfull
Thanks
Anyway.....
[4gb total]
Thanks
