Help with an issue
14 Oct 2007
My mate has dropped his PC off for me to have a look at...
I've cleaned all the componants of dust, and there was a lot of it, but the original problem is annoying me...
'No Signal' when I turn PC on.
It worked once, got to desktop, ran a ChkDsk and it said errors found can not continue.
Restarted PC, got Invalid BOOT.INI file.
Turned it off, and now when I turn it on, I get 'No Signal'...
any ideas on how to solve this issue? It's doing my head in lol
the no signal sounds like the GPU's driver has been deleted or something similar, but that doesn't explain the boot.ini
if you're using a vga/dvi port, try using an HDMI port if there is one or if you have a coverter try using a tv. They work differently and usually bypass installation errors and such on GPU's, might work
Its not the VGA connection, its the other type, and its the only type that is on there...I know its not my monitor as Im using that now on my own pc...
Do i get him a new GFX card or new HDD or what? im lost lol
try it through a dvi to hdmi if you can because of the refresh rate and such of the tv should affect it. if it works then it's hard drive
either way it sounds like software on the hdd or hardware of the hdd.
