I've been fixing a faulty laptop(Siemens/Fujitsu Amilo D7830) for my mate,turns out the charger was borked. Managed to buy another charger for it.
Been fidling with it today & got it back up & running,battery fully charged according to power management in the control panel.Now i have a problem with it beeping(short single beep over & over) when its running on the battery
Sounds like its coming from the system speaker. No beeping when its plugged in via the charger,only when the charger is unplugged from the mains
Do you think the battery could be on its way out as well ?
Getting no on screen error messages,checked device manager as well,all seems to be ok
Any ideas folks,any help would be appreciated
Rob
Sounds like its coming from the system speaker. No beeping when its plugged in via the charger,only when the charger is unplugged from the mainsDo you think the battery could be on its way out as well ?
Rob
Looks like it needs a new one
