Help with BF2.
24 Sep 2008
Edinburgh.
I'm trying to play BF2 online, I bought the game through steam but it's currently saying my CD-key isn't valid when I try to join a server. :(
Does anyone know what I should do? I'm kind of at a loss myself, not had much luck with steam recently I must say. :p
Sometimes a conflict in the updated files can prevent the game from properly identifying your CD-key. Usually, refreshing your CD-key will resolve the issue. Note that this will only correct the error if you used the same Windows account to install, patch, and troubleshoot the game. If you have switched Windows accounts at any point it is recommended you uninstall, reinstall, and repatch using the same Windows login.
If you have Battlefield 2
Click Start.
Go to Run.
Type regedit and hit OK button.
Click on plus sign next to HKEY_LOCAL_MACHINE.
Click on plus sign next to SOFTWARE.
Double click on Electronic Arts folder.
Double click on EA Games folder.
Double click on Battlefield 2 folder.
Double click on ergc folder.
Data displayed will probably have x9392 only.
Right click on it and select Modify.
Type in x9392 and then your CD key.
note: don’t include hyphens.
Example: x9392(your Battlefield 2 CD key here)
If you have Battlefield 2: Special Forces
Click Start.
Go to Run.
Type in x9392 and then your Battlefield 2 CD key.
Double click on Battlefield 2 Special Forces folder.
note: do not use your Battlefield 2: Special Forces CD key.
I don't think I can change any of that because it's installed using steam... :(
I tried but the directories you're telling me to look for don't exist. Anybody else bought BF2 off of steam and had this problem?
