help with bsod on bfbc2
Code:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Andrew\Desktop\022212-29546-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\temp\symbols\*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506
Machine Name:
Kernel base = 0xfffff800`02c5d000 PsLoadedModuleList = 0xfffff800`02ea2670
Debug session time: Wed Feb 22 12:09:19.378 2012 (GMT+0)
System Uptime: 0 days 0:00:09.548
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa8004f2c8f8, 0, 0}
Probably caused by : hardware
Followup: MachineOwner
2: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa8004f2c8f8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR:  0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  System
CURRENT_IRQL:  0
STACK_TEXT:
fffff880`031bd6f0 fffff800`02f1fc59 : fffffa80`04f2c8d0 fffffa80`03a55b60 fffff8a0`0000000c 00000000`00000000 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`031bdc10 fffff800`02dfff57 : fffffa80`04f2c8d0 fffff800`02e7a2b8 fffffa80`03a55b60 00000000`00000000 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`031bdc40 fffff800`02d675d5 : fffff800`02edbae0 00000000`00000001 fffffa80`04f8b830 fffffa80`03a55b60 : nt!WheapProcessWorkQueueItem+0x57
fffff880`031bdc80 fffff800`02ce4001 : fffff880`010d9e00 fffff800`02d675b0 fffffa80`03a55b00 00000000`0000055a : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`031bdcb0 fffff800`02f74fee : 00000000`00000000 fffffa80`03a55b60 00000000`00000080 fffffa80`03973890 : nt!ExpWorkerThread+0x111
fffff880`031bdd40 fffff800`02ccb5e6 : fffff880`02f63180 fffffa80`03a55b60 fffff880`02f6dfc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031bdd80 00000000`00000000 : fffff880`031be000 fffff880`031b8000 fffff880`037d95c0 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: hardware
IMAGE_NAME:  hardware
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_0x124_AuthenticAMD_PROCESSOR_BUS_PRV
2: kd> !errrec fffffa8004f2c8f8
Common Platform Error Record @ fffffa8004f2c8f8
Record Id     : 01ccf15ac9790523
Severity      : Fatal (1)
Length        : 928
Creator       : Microsoft
Notify Type   : Machine Check Exception
Timestamp     : 2/22/2012 12:09:19
Flags         : 0x00000002 PreviousError
Section 0     : Processor Generic
Descriptor    @ fffffa8004f2c978
Section       @ fffffa8004f2ca50
Offset        : 344
Length        : 192
Flags         : 0x00000001 Primary
Severity      : Fatal
Proc. Type    : x86/x64
Instr. Set    : x64
Error Type    : BUS error
Operation     : Generic
Flags         : 0x00
Level         : 3
CPU Version   : 0x0000000000100f42
Processor ID  : 0x0000000000000000
Section 1     : x86/x64 Processor Specific
Descriptor    @ fffffa8004f2c9c0
Section       @ fffffa8004f2cb10
Offset        : 536
Length        : 128
Flags         : 0x00000000
Severity      : Fatal
Local APIC Id : 0x0000000000000000
CPU Id        : 42 0f 10 00 00 08 04 00 - 09 20 80 00 ff fb 8b 17
                00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00
Proc. Info 0  @ fffffa8004f2cb10
Section 2     : x86/x64 MCA
Descriptor    @ fffffa8004f2ca08
Section       @ fffffa8004f2cb90
Offset        : 664
Length        : 264
Flags         : 0x00000000
Severity      : Fatal
Error         : BUSLG_GENERIC_ERR_*_TIMEOUT_ERR (Proc 0 Bank 4)
  Status      : 0xfa00000000070f0f
2: kd> !CPUinfo
CP  F/M/S Manufacturer  MHz PRCB Signature    MSR 8B Signature Features
 2 16,4,2 AuthenticAMD 3214 0000000000000000                   203b7dfe
Looks like a CPU/motherboard error. Are you sure you're not overclocking and have the right volts applied to everything (including memory just incase)?
cheers for looking at it
that was at stock settings :confused:
so no overclock on anything. every other game is fine its just bfbc2 which is weird. i even underclocked my card and it still did it
Maybe it just pushes the CPU more than other games (I remember it was a very CPU intensive game). What are your temps like when running the game?
dunno got me stumped just did linx ten loop run didnt go above 45
went in bfbc2 played whole round @ 3ghz underclocked and highest was 40c
didnt crash and bfbc2 is like you say more cpu intense that bf3
Might be worth resetting it back to normal and put some extra volts through the CPU to see if it stables up.
