Help with build my PC
30 Jan 2016
Hi!
So I have 2,5k to spend on PC but i don't rly know what's what now and don't know much about components. So can some1 help me build it from scratch.
Thx a lot.
Hi
Are you able to build the pc yourself ?
What parts do you need ? Just the tower ? or do you need a monitor, speakers, mouse and keyboard as well ?
A great option would be this Infin8 machine.
https://www.overclockers.co.uk/infi...rcooled-extreme-gaming-pc-fs-457-oe.html#t=g5
But in single 980Ti option which you can select from the drop menus. This comes to 2.6K
It will be very fast in games and with a big Overclock on a 4 Core 8 Thread i7 Skylake CPU also fast in Encoding, Photoshop, Rendering and number crunching.
This PC is fully watercooled so will operate almost silently with the components running at very low load temps for longevity of use.
Also dont forget Overclockers Warranty and great support service.
i have a m8 who knows how to build them pcs but he said it would be good idea to ask on forums and see what components ppl will advice. i dont get that much cash in for use very often so i want to make best of it. And yes i only need tower.
