Help with COD 4/5
Permabanned
19 Oct 2009
I know that this subject has properly been done to death with Vista etc but:
I have just installed Win 7 64bit and for the love of god can someone help :) I can't get COD4 to get of the start screen and COD 5 just goes round in a big loop once it's started.
Can't help i'm afraid, i was going to install my retail Win 7 64bit this weekend and then install COD5. Seeing your post feels me with dread :(
I'll report back if i see something that helps.
COD 5 runs ok untill you go to choose a game and leval you cant get past that just goes round and round. Its prob just my rig.
hmm seemed to work fine on mine I'm running 64bit too, have you installed the patches? not tried w@w yet though...
Both CoD4 & WaW running with no problems on win7 64 ultimate here, sorry that does not help directly, but at least means you "should" be able to sort whatever the problem is.
Computer, C Drive, Users, your name, App Data (this is a hidden file, so make sure you have it set so you can see it), Local, Activision. And there it is, like said earlier, just make sure you set file view to show hidden files.
