Help with Conroe Rig
5 Dec 2004
Hi Guys :)
I currently have a problem with my rig, it's running fine in windows @ 3.01ghz. This is dual prime stable for over 8hours, but it will totally lock up in any games after about 10minutes.
6300
DS3
1900XT
2gb HZ GSkill
Any ideas?
Cheers
i was asked to put the MCH voltage up.
appanrently prime will run smooths but with games without overclocking the MCH voltage tends to crash.
it worked for me. i forgot my value though
can you tell me what coltages / settings you have to get to the 3ghz stage, mine gets a bit unstable if i try there, currently very stable at 2.8ghz!
i hate overclocking.. im at 2800mhz as well. Vcore is at 1.3650 Ram is at 2.1 with latency of 444 12.
im also suffuring to get 3Ghz line. last time i done that the computer didnt turn on well so i must be doing something wrong. herphaps the vcore wasnt high enough but i hate messing around so...
What voltage have you got running through the ram, and what bios are you using? If you haven't already try increasing volts to the ram.
