Help with cpu cooler!!!!
8 Mar 2007
Poole, Dorset.
Well I`m thinking of purchasing a Intel Core 2 Quad Pro Q6600 "LGA775 Kentsfield" 2.40GHz (1066FSB)
http://www.overclockers.co.uk/showproduct.php?prodid=CP-143-IN&tool=3
I also want to replace my cpu u cooler to this...
Titan Amanda TTC-NP04TZ TEC & Heatpipe Cooling Fan (Socket 775)
http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-TI&tool=3
The MB I`m using is Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-152-AS&groupid=701&catid=5&subcat=174
The case I have is http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-TT&groupid=701&catid=7&subcat=715
Will the cpu cooler fit in the case and on the MB (space Issues really) :confused:
Any info would be great cheers!!!!
