Help with easy sli question
9 Dec 2006
@ManCave
i have the system (see sig)
i don't know how to check if sli is enabled?
i read to this was to go to nvidia control panel & under 3D settings select SLI Config.
But, its not shown .
both cards are shown in Device Manager
so how do i enable it? both cards are recongized in device manager would it be because im using 178.24 drivers? (had probs with 181.20) i might check the sli bridge make it sure if that will help?
Try reinstalling the drivers, that used to fix it last time I used it. You get a message asking you if you want to enable iirc, (this was on xp though.)
Do you have the cards in the top and bottom slot, as it wont work if you use top and middle slot.
You could always try the bridge on the other paet of connectors.
If its all set up correctly it will say SLI capable system detected when you startup windows
meatloaf are you sure? about card ports? im using the blue & white http://images.bit-tech.net/content_...-generation-x58-motherb/P6T-Deluxe_supper.jpg dont think i will able to use the black as psu is in the way
Positive mate, i have to have my 2 cards in the top and bottom slots. The lower card shouldnt interfere with the PSU, mine dosent. The 3rd slot is only used for Tri-SLI
Theres a pic of mine in this thread :)
http://forums.overclockers.co.uk/showthread.php?t=17965252
EDIT :
Ive just downloaded and read your manual and it seems that you do actually have them in the correct slots, the blue and white ones, so im not sure whats wrong
