Ahh just noticed that thread insert sort of thing. Can it do metric sizes like m6 etc?
It can, id have to have a look but I made a load of stuff with m* bolts.
fantastic, i can imagine people 3d printing wheel nuts and bolts for cars lol.It can, id have to have a look but I made a load of stuff with m* bolts.
Iv noticed that in tinkercad making thread holes in a shape results in size issues with the threads. Doing a metric m8 hole with threads the hole was so small only a m6 screw would fit in it properly.
Trying again now with thread and hole size for m6, m8 and m10 to see how it ends up.
Why this happens?
hmm so m8 hole should be 8.4mm diameter? the hole i ended up with was only able to fit in a m6 bolt.
im trying a few more test prints overnight
ahh good idea, at the moment iv got these 3 being printed:Measure it print a cylinder with a known inner diameter of say 10mm then measure the inside. It will likely be 9.x mm. After that compensate the model and reprint. You can do this with a couple of quick 5 min prints.
Did this today, printed 3 cylinders with holes inside, a 6mm, 8mm and 10mm.Measure it print a cylinder with a known inner diameter of say 10mm then measure the inside. It will likely be 9.x mm. After that compensate the model and reprint. You can do this with a couple of quick 5 min prints.
These printed out close to perfect in size so looks like there is an issue with printing out threadded holes which end up almost 2mm smaller than they are supposed to be.
Are you putting in threads as an extrusion or relief/cut into surface? It will ask you using the thread tool in fusion.
haha, just starting out on my journey. will need to try some software like autocad or fusion360 and see if threads is more accurate there.fusion is big boys toys, our man here is just starting out his journeyEventually he will find something that isn't simple in the likes of tinker and end up being forced but thought edge him in gently
