Help with eyefinity setup please
27 Nov 2008
UK
im sure i have read somewhere that when using eyefinity i need to do something with the 2d clocks but i cant find the info.
Basically this is whats happening i have a 5840 2gb eyefinity 6 edition with 3 monitors 1 obviously with a active dp-dvi adapter. The screen with the active adapter keeps flicking off every now and then.
Can anyone advise why and a solution please.
Thanks
Here is an error i get when i start COD:MW2 for example:
i've only ever had that error if i've flicked my dell (via dp) onto the hdmi input to watch tv :)
sounds like you might have a dodgy cable?
right i moved the active dp to another dp output on the card and so far no problems, i think however im doing something wrong in mw2 as i set the resolution to 6032*1080 (Bezel correction on) but it just looks like its majorly stretched rather than eyefinity.
ah MW2 doesnt support eyefinity so needs a thing called widescreen fixer for anyone else witht he same problem
Thanks
5840?
