- 5 Feb 2008
Currently my Western Digital Clavier Blue has my Vista 32 installed on it. However my Vista 32 is playing up and I want to reinstall it on a brand new hard drive and start from scratch.
My plan was to buy a Western Digital Clavier Black and install it into the computer (I have one of those Isotope systems) and take out the WD Blue (with the OS still installed on it). On the WD black install a clean Vista and start from scratch.
For my WD Blue I want to get a hard drive enclosure and access the data on it, with the OS still installed on it.
So my setup would be:
WD Black - Primary HD (boot) (internal)
WD Blue - Secondary (Access data only)(external)
The problem I have is, can I still access the data on my WD Blue with this setup? IF I uninstall the OS from the WD Blue I would lose all the data correct? So can I still access the data and transfer it from one to another from the WD Blue with the OS still on there, as an external hard drive?
Thanks
Thanks
