Help With Hz question
  • Thread starter Thread starter unknownsoldier64
  • Start date Start date
unknownsoldier64
unknownsoldier64
Just got the below setup and have been playing MW2 but im unsure what the Hz i should set my monitor is the more the better if your monitor can support it ? mine goes from 59 to 75 hz so should i set it on 75 ?
Also should i be playing with Vsync on or off ?
Asus Crosshair III Formula
1TB Samsung Spinpoint
650W Silverstone ST65ZF-GM PSU
4GB (2x2GB) Corsair Dominator DDR3, PC3-12800 (1600)
AMD Phenom II X4 955 BlackEdition,AM3, 3.2GHz,
1GB XFX HD5770
Arctic Cooling Freezer 7 Pro v2
Lancool K58 Black Advanced Tower
24" Iiyama PLB2409HDS-B LCD Wide Full HD 1920x1080 2ms 20000:1
yes higher is better.
vsync will sync your framerate to your monitors refresh rate ...the hz number.
it depends on how bad the tearing is really....if there is lots of screen tearing then you could enable vsync and see how that works.
