hi if you could have a look at the link below its a vid at 16. mins 34 secs he is talking about the terminal blocks
could some one explain to me what he has done i no he has took a modular cable from the psu to the terminal block gnd and 12v only i am assuming he as still ran the cables from the psu to to the gpu cd rom and hard drives as normal using sata connections but think he must to be running the power for pump to the terminal block but what else is he running as he has a separate once for all the lights and ther are a lot of more than one conection in the terminal block tar
kind regards thanks in advance
