Help with internal cables?
After looking at the case, there only seem to be two front USB ports, which means that the cables are meant to be like that and you are supposed to plug in one or the other. So leave the big blue USB-3 cable plugged in, and unplug the one that won't go on properly. :)
And yes the rear ports will all work fine as they are coming directly off of the motherboard.
Ok, optical drives and hard drives have two cables, SATA Data and SATA Power. The SATA Power come off of your power supply and your SATA Data should be loose and they connect from the drives to your motherboard.
Alright, I figured that one out before you guys got to me haha, just installing a had tray and then I should be good to go.
In the interests of safety, I would like to request on behalf of everyone on the power grid, a photograph of the inside of the whole PC before the first power on. :p
I'll do that, Im just gonna install the graphics card, can you also tell me what to do with that, and then, we can power up.
you just slot it into the upper most slot and connect the monitor via either DVI ( white connector ) or VGA ( blue connector )...or even HDMI
oh and dont forget the PCI-E cables :)
lAk0aEw
Well, here we go, just before post.
Yeah, I did that, and it POSTED I SHOUTED "MOTHERF*CKER YES!" It was amazing, ill sort the cables a bit more, and the big 24 pin cable keeps falling out, any suggestions?
If you've clipped it in properly it should be fine. Make sure it clips in place. If it is divided into a 20+4 pin cable rather than one 24pin block, make sure the two parts are lined up correctly and that one part isnt resting atop the other.
