hi
ive been asked to build a pc for a mate of mine. now the pc will be used for web browsing and general office work and some light gaming such as football manager and WOW etc. budget is under £230 but he's willing to go over a little if its worth doing
ive put together an intel spec but am stuck on which motherboard to have so was wondering can someone tell me whats the best motherboard for under £50 with integrated graphics that should play the above kind of games or do i have to buy a separate motherboard and graphics card and if so which one do you recommend.
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
23.49
Seagate Barracuda 7200.11 500GB SATA-II 32MB Cache - OEM (ST3500320AS)
£43.46
Intel Pentium Dual-Core E5200 "LGA775 Core 2" 2.50GHz (800FSB) - Retail
£58.74
coolermaster 330 case with cm 460w extreme power supply
£50
total is £175.69
23.49
£43.46
£58.74
£50
total is £175.69
