Help with MB and PSU.
11 Sep 2012
Hi there,
I've decided to go with a bit of a SFF build, I was going to build in the prodigy but the mini itx board annoyed me so I'm building into a FD Core 1000 (http://www.fractal-design.com/?view=product&prod=61), which can fit a normal sized MB and PSU.
This is currently the build:
YOUR BASKET
1 x Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card £239.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD £41.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £35.99
Total : £509.35 (includes shipping : £9.50).
Price for Motherboard: £90 or less.
PSU: £50 or less.
No - but i like the look and size :) and price.. £27.. I'm trying to stay under £600.
Thanks everyone, I've added idle's PSU and MB to my cart. :)
With what is already in you basket, plus mobo,Psu and case, that`s £600+
Btw, the Asrock board is out of stock.
Added a cheaper hdd.
YOUR BASKET
1 x ASRock Z77 Pro4-M Intel Z77 (Socket 1155) DDR3 Micro ATX Motherboard £77.99
1 x XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £49.99
1 x **B Grade** Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (HD-252-SE) £33.5
Total : £629.45 (includes shipping : £10.00).
If you've not got the case why not find a similarly priced atx case and get an atx motherboard. The z77 d3h (while its £80).
The antec one would be my choice or the bit fenix alpha/beta
EDIT: OCUK don't stock fractal anymore but im sure the core 3000 (atx) is not much more.
i would be getting the core 1000 from another source. i would like to keep the build pretty small - any suggestions for a small case would be great but the core 1000 has the simplicity i like. :) similar to the prodigy but half the price.
