Help with menu system ?
20 Sep 2003
Scotland
Hi folks,
I am working on a web design idea and have spotted a javascript based menu system I really like and would like to try and impliment into my own site. The menu can be found here....
http://www.londongolf.co.uk
Anyone any ideas how this works and if it can be modified from the source available on that site ?
Thanks.
Quick Google on some variable names doesnt return much which means it could be custom and Id be less likely to rip it off. If you are JavaScript savvy it shouldnt be too difficult if you do want to nick it, just looks like youll need the menu.js file and to follow the naming structures in the HTML which can be seen on the main menu items and the sub menu items.
Personally, I think its an awful menu, and the delay between hovering over the menu item and the menu appearing would be enough for me to exit the site post haste.
