Help with Messeges problem
28 Jan 2015
My two daughters aged 7 & 9 both have ipad minis which are on my Apple account. They are using messeges to their pals but all of them appear on my iPhone.
Can I stop them from going on my phone and allow them to continue to use the messeges as I dont have a problem with them doing so but is bleedin' annoying getting hundreds of received messege tones
TVMIA!!
Sure, go to settings, messages, Send & Receive and untick the addresses you dont want to receive on. Have a look at their ipads and do the same and remove your address from their ipads
Alternatively set them up with separate Apple accounts and then add them to your Apple Family Sharing group. You can still retain control of their purchases/use but makes it much easier to understand hows doing/sending what.
