Help with minimum spec PC
10 May 2008
Sandhurst, United Kingdom
Hi all,
Looking to build my ex a minimum spec PC. She's currently struggling with an archaic Pentium 4 that she inherited. Needless to say it takes about an hour for it to open a document, let alone display websites.
Cost is the key element - difficult to name a budget, other than to say that it must be absolute bare minimum. Like ridiculously low! She needs nothing fancy, just a minimum spec machine that can do word processing and browsing. That said, our 8 year old lad lives with her, and loves PC gaming, so if we can squeeze a basic graphics card in, great - but it is not essential.
She needs a monitor, but I can prob try and get a second hand 22 incher off fleabay - A new one would prob take the budget into unaffordable range.
No OS required - have Win7 I can put on it.
Any input most appreciated!
YOUR BASKET
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £41.99
1 x Intel Pentium G620 2.60GHz (Sandybridge) Socket LGA1155 Processor - Retail £41.99
1 x Asus P8H61-MX USB 3.0 Intel H61 (Socket 1155) DDR3 Motherboard - OEM ** £39.98
1 x BitFenix Merc Beta Gaming Case - Black £29.99
1 x PNY GeForce GT 440 1024MB GDDR5 PCI-Express Graphics Card - OEM £29.99
1 x TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) £23.99
1 x Swift 500W V2 Silent Power Supply £18.98
1 x Samsung SN-208DB/BEBE Slimline 8x DVD±RW SATA Drive - OEM £17.99
Total : £259.00 (includes shipping : £11.75).
259, although I can't add the gtx 460 to the basket as theres no ETA, however it says theres 5 in stock so you could call and ask, I got one, they are great cards. got it for my brothers budget gaming pc.
If you aren't interested in a higher end card, I'd spend the extra dosh on an SSD. makes it lightning quick. can pick up 60gb drives cheaply now.
YOUR BASKET
1 x SanDisk Extreme SSD 120GB 2.5" SATA 6Gb/s Solid State Hard Drive - (SDSSDX-120G-G25) £79.99
Total : £297.00 (includes shipping : £11.75).
Theres a speccy with a great 120gb SSD. If you don't have lots of files to store on it, 120gb is fine. I have around 25 full movies on mine and have 60gb free, after OS. and I have battlefield and diablo 3 installed to it.
for 297, your getting a good spec system with a nice SSD :)
YOUR BASKET
:eek::eek::eek: That power supply is SHOCKING !!!!!!!!!!!!!!
