If I could just get some of you more experienced guys to check my OC for me, to make sure somthings not drastically out that would be great, thanks.
Here's what I've managed to screw from my E6400 sofar:
Spec is in Sig.
FSB = 430 x 8
PCI @ 100Mhz
RAM running @ 860mhz 4.4.4.12 timings
FSB Overvoltage set @ +2v
gMCH set @ +2v
Vdimm set @ +3v
Vcore is set @ 1.46875v atm
Heres a quick Orthos pic to show the temps:
It 'Seems' stable enough here, but If I set the Vcore 1 step lower than this (1.4625v) it fails Orthos after about 5mins. Any higher with the FSB and it fails consistantly also. (I havnt dared go over 1.48 Vcore for fear of CPU meltdown
However I can get 3.2 Ghz stable @ only 1.3625v and lower Ram&FSB voltages too, I'm wondering if its best to leave it at that ?
Anyway, Is there any way of bettering this Overclock or is this my chips safe reasonable limit do you think, would lowering any of the voltages be wise or are they ok ?
ALSO, is the Vcore im running @ at the moment too high for Air cooling, my temps seem ok i guess (Tuniq is set to only about 1/4) ?
Thanks for any of your help folks, I'm learning slowly
Si
Spec is in Sig.
FSB = 430 x 8
PCI @ 100Mhz
gMCH set @ +2v
Vdimm set @ +3v
)However I can get 3.2 Ghz stable @ only 1.3625v and lower Ram&FSB voltages too, I'm wondering if its best to leave it at that ?
Si
Does 3.44Ghz look like my safe limit then I guess, could loosening my RAM timings help matters atall ?
