I would also recommend the Raijintek Themis CPU cooler over the 212 Evo, simply for value and performance. They are both 159mm tall however and your case has 160mm clearance so it might be tight. The 212 is far from a bad cooler though
The BeQuiet Pure Rock is shorter than both of those at 155mm and also a great performer
