Ive just bought a new case and transfered my old P4 socket 478 motherboard system innards into it but my new cases USB plugs which go on the motherboard are different to the ones on my old case,, In the picture the plug on the right was the one that ran from my usb port on the front of the case to the motherboard, but as you can see the new case has the two smaller plugs on the left from the front usb ports
Can these still be fitted on?? do I need an adaptor or something or am I knackered,,
also my audio plugs are different, but not too woried about this as im using a soundblaster card
thanks for any help
thanks for any help
