Help with Network setup
23 Mar 2005
I currently have sky fibre, and am using their box in the house. I am trying to get access in the garage, where the signal sits at about 1-2 bars. I picked up a TP-Link AX1500 Wi-Fi router to use as a wifi 6 access point, primarily to use my Quest 3 with the PC in the garage using airlink. I would run cat 6 between the 2 boxes if I could, but it is not feasible in the short term.
So, what I need is -
  • Wifi 6 connection in the garage, connecting the Quest to the desktop.
  • Connection linking the sky box with the TP-Link
  • A way of gaining access to the internet through the TP-Link.
I had thought about simply bridging the connections in windows 11, but well... windows 11 bridging... :rolleyes:
Any ideas?
Should add - current set up on the agarge PC:
  • Connects to the Sky box via a wifi 6 wireless dongle (I've played with different antennae to fix the signal, but no dice so far)
  • Connects to the TP-Link (hard wired) via the ethernet port on the mobo.
Powerline networking.
It's worth a shot.
Unless the garage is on the same ringmain there will be little point in even trying.
I (with kit I already had) tried powerline from the lounge to the garage in the past and the speed and packet loss were comically bad across the two rings.
Ours is (was) a new build, and even the few meters from the router to the PC (on the same ring main) lead to unusable speeds unfortunately.
The most annoying thing is I looked at getting the Access Point version of the TP-Link, but it is based on mesh, which is, apparently, aweful for what I'm trying to achieve.
Having thought about it a bit more, I think I might simply be able to live with what I have. The PC is connectede to the internet via the Sky. I can connect the Quest 3 to the PC using Virtual Desktop on the TP-Link connection, it just means the Quest won't have internet. Should be fine hopefully.
