Hello all
I just recieved and built my new machine:
E7200
Antec 300
Corsair VX 450w
Powercolor 4850 HD
Freezer 7 Pro
Samsung f1 320gb
I noticed after the lack of POST that I forgot to plug anything into the small 4 pin power connector on the mobo. So then I plugged in one of the remaining power connecters (half of a set of 8), but before turning on, I had a look at the VX manual which is pretty confusing.
Before I plug anything in and switch on again,my question is as follows:
the VX has two power cables, one which is 24 pin, and another which is 8 pin (split into two 4 pin plugs).
Obviously I should plug in the 24 pin one, but is it correct to plug in half of the 8 pin one (i.e. a 4 pin plug) to the mobo above the CPU?
My mobo is a Gigabyte GA-P35-DS3L.
Any help much appreciated!
E7200
Antec 300
Corsair VX 450w
Powercolor 4850 HD
Freezer 7 Pro
Samsung f1 320gb
