I wonder if anyone can help me. I've recently bought a few bits for an upgade:
Pentium D 805
Asus P5P800
ATX 20pin to 24pin converter
I have been hoping to keep my X850XTPE, Ballistix and Enermax 460w PSU with this new gear but when I set this up I get nothing. It shows power on the mobo and everything spins up correctly but no monitor signal or beeps. It will eventually spin down again.
I have tried resetting the bios and moving the ram around, I even tried using some old ddr33 to no avail.
The thought occurs that I should have plugged the speakers in before I rebuild the old machine, because I understand the Asus boards run there errors through there.
My other worry is that it's just this 20-24pin converter is rubbish?
I should also point out that I have not build a 775 system before, are there any pitfalls I should be away of?
Any help much appreciated.
Pentium D 805
Asus P5P800
