Help with new build
18 Sep 2010
Sheffield
Hi i got a new build today made it all fine and it turned on fine but it keeps coming up with out of area on my screen then i have to restart it. But then it keeps turning it self on and off any ideas?
Hmm, what type of screen you using and connections.
On your build are all the power connections connected including the 8 pin for cpu power and memory in the correct slots.
Also try a CMOS reset.
Its stopped turning it self on and off now but every now and then it says that out of range i think it is. Manged to install the Nvidia drive update see if that helps at all.
Ok seems fine whats the best tempature monitor for everything going to run 3d mark 06 see what temps are like.
What is normal for my spec?
is it your graphics card not plugged in properly or ram, my new build was reseting but it was something to do with putting my harddrive into a diferent mode plus my mobo had dual bios
