Help with new Case and maybe AIO
11 Oct 2011
Birmingham
MONITOR - Samsung C32HG70 32 2560x1440 VA FREESYNC 144Hz Gaming Quantum DOT HDR Widescreen Curved Monitor
MEMORY - Corsair Vengeance RGB Grey 32GB 6000MHz AMD/XMP iCUE DDR5 Memory Kit Fast CAS 30
PROCESSOR - AMD Ryzen 7 9800X3D 8 core processor
MOTHERBOARD - ASRock AMD B650 PRO RS ATX DDR5 Motherboard
POWER SUPPLY - Will need to open case and have a look :P but i know it 1000watt
GFX CARD - AMD Radeon RX 9070 XT 16GB
NVMe - Seagate FireCuda 520, 2 TB, Internal SSD, M.2 PCIe Gen4 ×4 NVMe 1.4, with speeds up to 4,850/4,750 MB/s,
CPU COOLER - Thermalright Assassin King 120 SE ARGB CPU Air Cooler
CASE - Lian-Li PC-O11 Dynamic Midi-Tower - Black Window
HI all my front class panel has broken on my Lian-Li PC-O11 Dynamic Midi-Tower so its time for a new one, would some help me first one please, (would like a while one this time) with AIO for my processor and 6 fans that will fit in the case also ( RGB would be nice)
thank you all
thank you all
I'd also look into a new monitor I had the 27" version of that Samsung, newer gen VA panels have gotten better (now have AOC 27MXN 180hz VA mini LED)
Recommend Antec Flux / Pro.
Stick with your existing cooler nothing wrong with that.
I did ask in the Case section of the forums but i haven't found anything yet Monitor wise. still looking, the Antec Flux / Pro. while it looks OK i don't like the wood on the case, and the cooler i have i know its good but i is like milometers away from the side panel glass on my case and it bugs me. also i would like an all white case, also gfx virtural mount if possible
Hey all me again, i have got new fans an AIO and Cooler master vertical GPU holder kit v3, i think the case is little small as i couldn't get 2 of the fans under the GPU holder
i think maybe a full tower case would look better and fit everything with some space left over ..
could you please recommended me a Case where i can put everything in with the other 2 fans please.. here are come pics
