Help with O/Ced set up
7 Jan 2006
Hi All,
I bought the following system from overclockers about 14 months ago and the system has been great.
i7 950 3.06 overclocked to 4.0Ghz
60GB SSD
nVidia 470 GTX 1248MB card
6GB DDR3 1066 RAM
A few months ago though on booting up something indicated that the system was not in overclock mode. Also, even at load, the CPU was still in windows indicating 3.06GHz.
I went into the BIOS and to tools:
http://postimage.org/image/locfe5kkz
From there I went to Load From --> Profile 1 ocuk:
http://postimage.org/image/okcy13ogr
But then I get on to this screen and I'm stuck as to what I should do from here.
http://postimage.org/image/3mxvu3fxv
Is the CPU correctly o/c to 4.0GHz? Many thanks for any advice / help.
Hi All,
60GB SSD
6GB DDR3 1066 RAM
Your trying to load a CMOS that's not what you want to do. Select the profile from the right hand side panel if you can or click the button that says start oc profile (at the bottom).
Post some more screens of what they do.
