kemistry said:
ive tried upping the mem voltage and the same thing happens
i have this thing called Adjust CPU Ratio (going upto x11), its on the startup setting atm, but what is this?
The CPU ratio is the multiplier. CPU speed is front side bus (the 1:1 memory speed) * the multiplier. On the AMD 64's on all but the FX range the multiplier is locked and cant be modified**.
**its probably possible with a fair amount of arsing around and silver paint
With an AMD64 setup you have 3 "major" bits you need to work out and set correctly
1) Bus speed/memory clock - this will default at 200MHz
2) CPU ratio - this is stuck at a set value
3) HTT - HyperTransporT- this is a multiplier of the bus/memory clock
As the bus speed goes up the CPU goes quicker due to the multiplier. On a x10 multiplier (make figures easy) you'd start with a 2.2 gig processor (further confused by the AMD speed rating). For each Mhz you add to the bus speed your processor gains 10Mhz. The HTT gains 4/5mhz (depending on the multiplier set - default is 5 so even 1Mhz increase of Bus speed takes you to 1005Mhz which is over the "safe" limit).
To achieve an overlock your looking to increase the Bus speed thus getting more from the CPU due to the ratio. Other bits cant handle the speed increase (mainly the HTT) so the multiplier on these needs to be dropped to balance things. As said HTT cant go over 1000Mhz as a rule of thumb.
As the memory works at the bus speed your memory also has to be able to handle the increase, this is where the memory/bus ratio setting comes in. At 200Mhz bus your RAM is running at 200Mhz DDR also known as PC3200. To keep ram stable you either use the ratio setting (so at 4:3 the ram is running at 150Mhz DDR to start with) or get Ram that can take a higher setting. This leads to a whole thing about memory speed vs memory timings which you'll have better answers from the memory section on.
The above is a very basic explanation without any real practical "method" but covers most of the terms and ideas you'll need to know and get your head around before you can start to make use of other advice given
Sorry if any of that covered ground you knew, handy educational bit anyway hopefully.
