Help with OC settings
20 Oct 2009
ESSEX
Hi,
I'm trying to get to 4GHz on my i7 920,currently running @3.8GHz no problem,
i set the multiplier to 20,run OCCT and get error on core 2,temps seem OK about 56c but get the error message after only 10 secs.
the cpu-v is at 1.30, should i increase it.
cheers
Vcore of 1.3v should be good to start to start with assuming you have a D0 chip. Up your QPI to 1.3v also for 4GHz. Once booted test for stability and lower volts until unstable and back up one notch.
