I have just purchased 2 x 12cm Akasa Amber Ultra Quiet Fans and 2 x 8cm Akasa Amber Ultra Quiet Fans.
I currently have an Akasa 961 sat on the cpu and a Zalman VF900 CU sat on my GFX.
I am fitting the 12cm Fans as front intake and exhaust as standard but i'm unsure as to which direction to have the 8cm one's which will go on the side of the case.
As you can see, the top one is directly in front of the cpu and the bottom is where the GFX is. Now do I have the top as intake and the bottom as exhaust or shall I have them both as intake?
Many Thanks
Many Thanks
