Help with Oracle PL/SQL and Objects...
11 Dec 2004
Hi,
I wonder if you can help me, I am having some trouble dealing with Oracle objects in PL/SQL. I can declare them, populate them and read from them without any issues.
But I am having some problems with trying to copy records in to other records of the same type, and also with updating existing records. I've made a mock up piece of code below to explain what I mean, it may have a few mistakes as I've written it in notepad but should be reasonably clear.
First I have created a record type, which contains attributes relating to a person.....
Code:
CREATE OR REPLACE
TYPE PERSON_RECORD_TYPE AS object (
				Person_ID		NUMBER(3),
				Person_Name	VARCHAR(20),
				Person_Age		NUMBER(2),
				static function new return PERSON_RECORD_TYPE );
CREATE OR REPLACE
TYPE BODY PERSON_RECORD_TYPE as
    static function new return PERSON_RECORD_TYPE is
    BEGIN
        return PERSON_RECORD_TYPE (
                                    	NULL,
					NULL,
					NULL,
					NULL,
					NULL
    END;
END;
Then I have created a table type, which is a table of the person record type......
Code:
CREATE OR REPLACE
type PERSON_TABLE_TYPE as table of PERSON_RECORD_TYPE;
Finally I have created a procedure which recieves an instance of the person table type and reads through it using a cursor.....
Code:
PROCEDURE ADMIN_PERSON (incoming_person	IN	PERSON_TABLE_TYPE)
IS
-- This is a local record declared as the same type as the incoming object
local_person  PERSON_TABLE_TYPE;
-- Cursor to select all from the incoming object
CURSOR select_person
IS
SELECT 	*
FROM 	TABLE ( cast (incoming_person AS PERSON_TABLE_TYPE));
BEGIN
-- Loop to process cursor results
FOR select_person_rec IN select_person
	LOOP
		/* Up to this point works fine...*/
		-- If I want to store the current cursor record in a local record of the same type, I can do this....
		local_person.person_id	 	:= select_person_rec.person_id;
		local_person.person_name 	:= select_person_rec.person_name;
		local_person.person_age		:= select_person_rec.person_age;
                -- QUESTION 1
		-- The above works fine, but in my real example there are a lot more fields
		-- Why cant I set the local record to the value of the cursor record like this below..
		local_person := select_person_rec;
                -- The above line gives a pl/sql error - expression is of wrong type, (as far as I can see the records are of the same type?)
                -- QUESTION 2
		--Also how do you update an existing record within the original object, I have tried the following but it does not work
		UPDATE  incoming_person
		SET		age = (age + 1)
		WHERE	incoming_person.person_id = '123';
                -- The error here is that the table does not exist
	END LOOP;
END;
So I hope that you can see from this, I have two problems. The first is that I can store the current cursor record in a local record if I assign each attribute one at a time, but my real example has a large number of attributes. So why can't I just assign the entire cursor record to the local cursor record?
I get a PL/SQL error "Expression is of wrong type" when I try to do this.
The second question is with regards to the update statement, obviously this doesn't work, it expects a table name here instead. So can anyone show me how I should update existing person records in the incoming table type to the procedure?
I hope this makes sense, but I don't think I have explained it very well!!
Any help will be gratefully recieved!!
Thanks
Question 1
You need to select a column from your returning cursor eg "select_person_rec.Person_ID"
Question 2
incoming_person is not a view or a table, I think thats why it can't find it :)
Hope this helps :D
