help with passing query strings please
16 Feb 2008
Staffordshire
Hi,
I have been having problems a while now but through determination I think Iam nearly there.
I have a regular html form, lets say "landingpage"
It then sends a query string to "anotherpage.php" and displays the result.
all good now
well the problem is that I can call for example google.com and display the search but if I change the Url to my required one it loads a default site.
here is the code:
landingpage:
Code:
<form method="post" action="landingpage.php"  target=content>
        <input type="text"  name="lookfor" value="Search"  />
        <input type="submit" value="Search"/>
</form>
anotherpage:
Code:
<?php
if(!empty($_POST['lookfor'])){
   $url = "http://google.com/search?q=".$_POST['lookfor'];
   $content = file_get_contents($url);
   echo $content;
now I need to replace the google url (which works) with this:
http://www.*********.co.uk/modules/shop/searchrated.asp?
Ok it dosnt work, it has to be a query string problem i figure, or is it because Iam calling .asp from php?
cheers guys
You're taking form data and putting it into a URL, so you may need to URL encode it.
It doesn't matter what the languages in use are since the requests/responses are being marshalled through HTTP. You may need to look more closely at the specification of the .asp page (i.e. what does it require for input) and/or the parsing it is doing (if you have access to see that), in case it's doing something silly based on user agent (browser) detection for its responses or similar.
