- 3 May 2017
Hi, new poster here!
Over the years I've build a gaming rig, the last peice of the puzzle being a graphics card. Since installing said card it's been running hot, and subsequently been heating the rest of the PC. The specs are as follows:
Silverstone Raven RVZ01 ITX case
MSI Z87i Gaming ITX mobo
16GB RAM
Intel I7-4770k CPU
1 x Noctua NH-L12 low profile cooler in single fan config blowing air out the top of the case (in theory)
1 x standard case-supplied 120mm fan above the CPU cooler
ASUS GTX1070 Turbo with reference blower cooler
2 x Noctua NF-F12 120mm fans below the cooler pulling air from below the case up into the GPU (in theory :/ )
SSD
The case sits as a desktop on a desk, with reasonable clearance around the sides other than the base (10mm clearance I guess?)
The GPU fan rarely goes above 50%, I have tried running a custom map to get the fan running higher earlier, but it gets LOUD.
Temps when gaming are CPU 50 deg, GPU 80 deg. Not exactly a demanding game either....
Stock clocks running across the board.
Can anyone give advice as to how to get this thing to run cooler? The GPU backplate is too hot to touch after a couple of minutes of a gaming session, and the heat is dissapating across the mobo backplate as well. I fear for the components - the network started to go on the blink after an extended session and that port is close to the GPU, improved once cooled.
Thanks in Advance
16GB RAM
Intel I7-4770k CPU
SSD
Thanks in Advance
