help with pc upgrade
26 Jan 2012
MSI HD 6870 ATI - AMD Radeon Graphics Card - 1GB
R6870-2PM2D1GD5/OC - 1GB MSI HD 6870, 4200MHz GDDR5, GPU 900MHz, 1120 Stream Processors, DVI-D/ DLDVI-I/ HDMI/ 2x Mini DP
Corsair Memory XMS3 8GB DDR3 1333 Mhz CAS 9 Dual Channel Desktop
CMX8GX3M2A1333C9 - 8GB (2x4GB) Corsair DDR3 XMS3, PC3-10600 (1333), Non-ECC Unbuffered, CAS 9-9-9-24, 1.50V
Corsair Enthusiast TX V2 CMPSU-650TXV2UK 650W Power Supply (PSU)
CMPSU-650TXV2UK - 650W PSU, Corsair Enthusiast Series 650TXV2UK, 85% Eff', 80 PLUS Bronze, SLI/CrossFire, EPS 12V, Quiet Fan, ATX v2.31
SilverStone AP121 120mm Fan Silver
SST-AP121-BL - 120mm SilverStone AP121 Air Penetrator 1500rpm FDB Blue LED Fan
I use Windows 7 64-bit
My motherboard is a ASrock M3A UCC
the motherboard can be upgraded to 16 gb ram (Special board)
Case is MARS BLUE GAMING ATX CASE PC COMPUTER TOWER & FRONT LED FAN
Will all of this fit in my case, and maybe any reccomendations or changes.
1600MHz Dual Channel Kit, would have been better, rest is good, Please remove competitors name before you get in trouble.
M3A UCC
- Dual Channel DDR3 memory technology
- 4 x DDR3 DIMM slots
- Supports DDR3 1800(OC)/1600/1333/1066/800 non-ECC, un-buffered memory
- Max. capacity of system memory: 16GB*
*Due to the chipset limitation, if you adopt 4GB or more memory, the actual memory size may be less than the installed memory size.
http://www.asrock.com/mb/overview.asp?Model=M3A UCC&cat=Specifications
If you allready have 8gig & are adding more then get same speed as your ram. But 8gig is enough for most people.
M3A UCC
ok thanks, how do i find what my current ram make is?
What are you paying for the parts?
If you are into video editing maybe consider switching to the EVGA 460 SOC for £120. You can overclock it further to close to 6870 performance but it will also give you cuda support. Adobe and a few other programs can use cuda to reduce encoding times ;)
Oh OCuk are doing the XFX 650W MODULAR PSU for the same price as the Corsair one you have chosen.
Comes to around 270 for everything but still looking for the best versions of everything, I am also going to use the comp for gaming
Go for the 460 SOC, from what I read it can be easily overclocked to be the same as the more expensive cards because of cuda, I am getting one my self for gaming.
