Help with PHP and Apache for sig script wanted
Just investigated further, and it doesn't have an effect on font size at all.
What appears to be happening is that if the number in that variable is greater than 5, and it PHP doesn't have any external fonts installed, it just selects font 5 as a default (and the font is physically larger, at least on my installation).
Fontsize =1
seti.php
Fontsize =3
seti.php
Fontsize =5
seti.php
Fontsize = 500
seti.php
It seems that your version of PHP comes with different fonts.
[edit]Beaten to it :)[/edit]
My PHPinfo is here if it's any help.
It's very strange :confused:
(You also won't get the "Site Down" messages with the other script :))
OK, using the following code:
Code:
<?php
//Code for overlaying SETI stats over a JPEG or PNG image
//By Phil Cutler (kaiowas) of Team OcUK Oct 2002
//Revised by Mark Gray Apr 2003
//Visit the OcUK team forum: [url]http://forums.overclockers.co.uk/fo...php?&forumid=39[/url]
//Uses a local file to cache the users total and reduce bandwidth hit on Berkeley
//Setup Variables For Sig
   $UserEmail="[email protected]";
//   $PreText="Team OcUK - Get WU's Or Die Tryin'";
//   $PostText="WU's owned";
   $TextRed=0;
   $TextGreen=0;
   $TextBlue=0;
   $FontSize=10;
   $TextX=164;
   $TextY=-8;
   $ImageURL="http://www.all-one-word.com/setisig/feek.png";
   $UpdatePeriod=900; //Maximum frequency in seconds at which the script will poll Berkeley
//Setup Variables For Webspace - Must be absolute paths
   $LocalFile="c:\Program Files\Apache Group\Apache2\htdocs\setisig\WUTotal.dat";
   $FontFile="c:\Program Files\Apache Group\Apache2\htdocs\setisig\times.ttf";
   if(!file_exists($LocalFile) or !FileMTime($LocalFile) or time()-FileMTime($LocalFile)>$UpdatePeriod)
    //Get Total Number Of WUs from personal stats page at Berkeley
    $fp =@fopen ("http://setiathome.ssl.berkeley.edu/fcgi-bin/fcgi?email=" . $UserEmail . "&cmd=user_stats_new", "r");
    if ($fp)
     while (!feof($fp))
      $WebPage.=fgets($fp,200);
     fclose($fp);
     if (strpos($WebPage,"No user with that name was found")==0)
      $TotalStart=strpos($WebPage,"Results Received");
      $StartPos=strpos($WebPage,"<td>",$TotalStart)+4;
      $EndPos=strpos($WebPage,"</td>",$StartPos);
         $WUs=ltrim(rtrim(substr($WebPage,$StartPos,$EndPos
-$StartPos)));
     else
      $WUs="User not found.";
     //Update Local File With Total
     $Output = fopen ($LocalFile, "a");
     ftruncate ($Output, 0);
     fseek($Output,0);
     fwrite($Output, $WUs);
     fclose($Output);
   //Read Total from Local File
   $Local=@fopen ($LocalFile, "r");
   $WUs=fgets($Local,200);
   fclose($Local);
   //Build Text String
   $Text=$PreText . "\r\n" . $WUs . " " . $PostText;
   //Create Image
   $size = ImageTTFBbox ($FontSize, 0, $FontFile , $Text);
   $im_x=abs($size[4]-$size[0]);
   $im_y=abs($size[5]-$size[1]);
   if (substr($ImageURL,strlen($ImageURL)-3,3)=="jpg")
    //Create a Sig image based on a JPEG
    Header("Content-type: image/jpeg");
    Header("Expires: " . gmdate("D, d M Y H:i:s", time() + 900) . " GMT");
    $im_size = GetImageSize ($ImageURL);
    $imageWidth = $im_size[0];
    $imageHeight = $im_size[1];
    $im = ImageCreateFromJPEG($ImageURL);
    $text_color = imagecolorclosest ($im, $TextRed, $TextGreen, $TextBlue);
    if ($TextX+$im_x>$imageWidth){$TextX=$imageWidth-$im_x-2;}
    if ($TextY>$imageHeight){$TextY=$imageHeight-2;}
    imagettftext ($im, $FontSize, 0, $TextX, $TextY, $text_color, $FontFile, $Text);
    ImageJpeg ($im);
    ImageDestroy ($im);
   elseif (substr($ImageURL,strlen($ImageURL)-3,3)=="png")
    //Create a Sig image based on a PNG
    Header("Content-type: image/png");
    $im = ImageCreateFromPNG($ImageURL);
    ImagePNG ($im);
    ImageDestroy ($im);
This produces lots of errors
I have the font file in the location specified, the script has created a file called WUTotal.dat but when I view that file in notepad it contains "User not found."
Summat's not right.
K.
The script (besides being the version which falls over when berkeley's down, I'd advise you to look at the end of the thread :)), can't find your font file or the image by the looks of it.
Try putting the font in a directory with no spaces in the name. It doesn't like spaces IIRC. Also your image is not externally accessible. See here. Try accessing it with a path.
Also, uncomment the following :
as they are being called later on in the script. Rather set them as follows:
$PreText="";
$PostText="";
That may help a bit
It's definitely choking on that image. Use a local path for the image file and font file, but change all the backslashes to forward slashes.
Thanks for your help everyone, it's working well now and I've updated my sig so it's using it.
K.
