Hi,
Was wondering if anyone can help.
I have a 250mbps connection with Virgin Media. I am experiencing latency issues that are stopping me from playing games.
I've tried using both WiFi and Ethernet - both have the same issue, though ethernet is maybe a little more reliable.
A few questions:
A few questions:
- I have a Hub 3 - would buying/getting a new router help?
- Virgin (on X/Twitter) have tried to tell me that I need to upgrade the speed as there are 17 devices connected - would this help? (I don't think so - I tried this morning and only the device I was testing on was in use and it still happened). Wouldn't want to do it with Virgin anyway.
- Is VM just bad for latency - I recently got access to OpenReach FTTP if that would improve things?
- Anything I can do to fix/reduce the issue?
In your position I'd just jump to Openreach based FTTP. In fact, I recently did just that. Base latency went down from 22ms to 9ms, and no more bloat or jitter.
