hi all this is the set up i have and am selling but would like some information on how much you all think i would get for it or advertise it at 12 months old
pc spec
windows 7 ultimate x64 install on ssd only
1 x log itch keyboard and mouse
1 x hitachi 19" 1080p tv used as a monitor and a 19" tft used for dual screen
Xigmatek Utgard Tower Case Black £66.37
HIS ATI Radeon HD 5830 1024MB GDDR5 PCI-Express Graphics Card
£109.99
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail
£108.32
Asus M4A89TD PRO AMD 890FX (Socket AM3) DDR3 Motherboard
£106.66
G.Skill RipJaw 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit
£83.32
Patriot PS-100 64GB 2.5" SATA-II Solid State Hard Drive
OCZ ModXStream Pro 700w Silent SLI Certified Modular Power Supply
£58.32
Western Digital Caviar Blue 1TB SATA 6Gb/s 32MB Cache WD10EALX - OEM
£44.98 x 2
warter cool spec
Water Blocks EK-CoolStream RAD XT 240 2 £75.98
EK Water Blocks EK-Supreme HF - High Flow Plexi £51.05
Water Blocks EK-FC5870 V2 £65.35 full cover for gpu
XSPC Single 5.25" Bay Reservoir (Alu Front) £25.52
12V Laing DDC 18W Ultra + XSPC Acrylic Pump Top £71.48
1/2"ID - 3/4"OD Compression Fitting £3.36 x 10 £33.60
XSPC 1/2” ID 3/4” OD Blue/UV Blue High Flex Hose Per Metre £3.05 4
£12.20
KILLCOIL-P Pulse Modding Silver Kill Coil (Anti Algae) £4.08
D12SL-124UB Yate Loon D12SL-124UB 120mm Case Fan UV-Blue Blue LEDs 1350RPM £5.09 5 £25.45
H2Mayhems 1 Ltr Ultra Pure H20
1 x logitch key bord and mouse
1 x hitachi 19" 1080p tv used as a monator and a 19" tft usrd for dule screen
thanks in advance
pc spec
£109.99
£108.32
£106.66
£83.32
£58.32
£44.98 x 2
warter cool spec
£12.20
thanks in advance
